help with tire pressure for my vinson
Old Jan 1, 2006 | 10:07 PM
calsatman's Avatar
Default help with tire pressure for my vinson
just put a set of stock size dirt devils on my new vinson (less than 40 miles). the tires handle way better than stock but the ride seems a little harsh. i know the dirt devils wont ride as smooth as the stockers but i was wondering what kinda air pressure should i be runnin in these tires, i think my buddy put 11 pounds in them.
Old Jan 1, 2006 | 10:16 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
11 psi is way too high for ATV tires. You'll find that the DD's have thicker sidewalls than your OEM tires, they certainly don't need much more pressure than the stockers unless you are carrying lots of extra weight. Try setting them down to about 5 psi or so and see how it feels. If the ride is still harsh and bouncy, go a little lower - I wouldn't go below 4 psi. If 5 psi feels like it wallows, bump it up a pound or two.
My brother has stock size Dirt Devils on his Prairie 650. He carries lots of gear in front and rear cases. He runs 5.5 to 6 psi in the back and 5 psi in front.
Jaybee
Old Jan 1, 2006 | 11:51 PM
calsatman's Avatar
thanks for the reply, ill try airing them down and see if that helps the ride
Old Jan 2, 2006 | 01:10 AM
GC1218's Avatar
This bring up a good question. I have been useing the air pressure gauge that comes with the King. Does anyone know where you can buy a nice low pressure gauge.
Old Jan 2, 2006 | 02:34 PM
5spdvinsn's Avatar
There is a table on the rear right fender that tells the recommended pressures, these are usually a good starting point. Start there and fine tune until the ride is right for your style of riding.
Old Jan 2, 2006 | 06:24 PM
BobVT's Avatar
Cabelas sells a decent low pressure gauge.
Old Jan 3, 2006 | 09:05 PM
GC1218's Avatar
Thanks
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Hw00d
Sep 10, 2015 08:53 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
