Z400 cams and head
Old Jan 16, 2006 | 10:04 PM
  #31
mucky's Avatar
Default Z400 cams and head
well I bought the 470 kit from tudors performance.
went with the 13.5-1 piston, should have it all back together sometime next week
will have to rejet, so I need to find a good shop here in phoenix that really knows what
they're doing for jetting. im not that great at it.
the head should be done in a few days so I can shim the valves while I'm waiting
for the 470 kit to arrive
Old Jan 16, 2006 | 11:04 PM
  #32
BlackKawi400's Avatar
While your looking around for a shop, look for a dyno too and get us some hp numbers on that beast!!!
Sounds awsome, post pics asap
Old Jan 17, 2006 | 06:50 PM
  #33
kawiking's Avatar
S W E E T ! ! ! ! !
Old Jan 17, 2006 | 09:12 PM
  #34
mucky's Avatar
once I get it back together and broke in i'm going to put it on the dyno with stock gearing
theres a place about 10 miles from me
the head is done i just have to go get it, all my parts are here except the
470 kit so I should have everything ready to put together when it comes in
which should be monday, they're waiting for the piston to come in
cant wait to see how it will do
Old Jan 18, 2006 | 04:35 PM
  #35
witti's Avatar
Just wondering if you had it dynoed before? We would get a better idea of your gains.
Should be a good setup.
Old Jan 18, 2006 | 11:06 PM
  #36
mucky's Avatar
yes it was dynoed right after I had the 440 kit installed
it had 36 ft lbs of torque and 44 hp at the wheels at 6500 rpm
top speed 83 mph so I cant wait
still working on the jetting for it
Old Jan 19, 2006 | 09:20 PM
  #37
kawiking's Avatar
who carries the hammerhead piston? either i'm going 434 or maybe try cams and port/polish with a high compression. im trying to save some money for another
bike(2-stroke maybe).im not sure if iu want to save and put everything into my 400.i was thinking 13:1 (je,weisco,or hammerhead??)piston.i'm getting a set of cams and kibblewhite valve springs for $150. so i was thinking good port job and piston for now.
any info would be great,you guys have given me so much already thank you. wife - kid- $=[img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
mucky were did you get your cam chain???
Old Jan 19, 2006 | 10:14 PM
  #38
CP/VCP makes the "Hammerhedz" piston.
Bare Performance Hammerhedz
As for the timing chain, check this site out.
Advantage Cycle
Ask for Paul
Old Jan 19, 2006 | 10:58 PM
  #39
mucky's Avatar
advantage cycle
Old Jan 20, 2006 | 03:24 AM
  #40
kawiking's Avatar
am i going to need to get my valves shimmed?? if i do ,should i get the hot cam shim set ,($80)??
mucky , i may go with cams ,springs,high comp(13:1) and hopefully a good port job anything i need to know about that set up?? should i lower my rpms back to stock???? whos doing your porting??
