ozark parts
Old Jan 13, 2006 | 09:04 PM
bisho12's Avatar
Default ozark parts
Hi Guys,
I just bought a 2002 ozark for my son for $800. The only problems are the wheel bearings on both wheels are shot and wrecked the hub and rotors and the right front caliper. And brake pads. Other than that it runs great shifts and looks ok but needs a cleaning.
Can someone help with parts as far as what models and years are the same as this one?
Thanks,
Bob
Old Jan 13, 2006 | 09:38 PM
CobraR6's Avatar
Default ozark parts
Rocky Mountain ATV
They might have what you need, not sure though. Try the dealer, and at least get an idea of what you are looking for as far as price. You could also try ebay, you might end up getting lucky and finding what you need.
Old Jan 15, 2006 | 01:07 PM
Braggon's Avatar
Default ozark parts
I got new pads from ebay and they worked great, less than half the price of the dealer and the pads are thicker, the seller was extremeshop. I also replaced the front bearings, from rocky mountain atv. the new bearings had seals on both sides and the oem ones only had them on one so they should last longer as well. For the other parts I would check ebay first as I've seen several there that were parted out and a new oem one would be over priced.
Old Jan 15, 2006 | 01:50 PM
bisho12's Avatar
Default ozark parts
Thanks Braggon.
The problem i have is I need a left front spindle, right front brake caliper and 2 front hubs. I need to know which models fit each other. ebay doesnt have a lot of ozark parts.
I have ordered from rockymountain before but i want used spindles and hubs if possible.
Thanks and let me know if you find any online.
Bob
Old Jan 15, 2006 | 09:47 PM
GrnXnham's Avatar
Default ozark parts
I found it's tough to find used parts on a quad that has only been around for four years.
You might try eBay. Sometimes I have seen them parting out an Ozark there. If you want the parts soon, however, you will probably need to buy new.
I use bike bandit
www.bikebandit.com
Old Jan 16, 2006 | 12:37 PM
Lolli2's Avatar
Default ozark parts
Try ebay. There's been a few people parting out Ozarks. I think they only made a few 2002's. I'm pretty sure they're the same as the 2003's. We have a 2003. Not sure about newer ones. You can probably call your dealer and ask if the spindle is the same part number for all years. Or, you can go to bikebandits.com and look up the spindle part number for different year Ozarks. Just make sure it's the same part number if you find one from a different year.
Old Jan 28, 2006 | 11:24 AM
91CavGT's Avatar
Default ozark parts
I own a 2005 Ozark and everything I have bought for it so far has also been listed for a 2002 model. I compared mine against a 2002 model and everything looks identical.
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
traumajunkie
Jul 5, 2015 03:03 PM
