z400...running...bad...
Hey guys, my z400 is running pretty bad.Like when you start it it will idle fine but once you give it throttle it will die.No it is not the parking brake limiter, i checked that once it started.It is not the reverse limiter either.Please help...
~Mike~
~Mike~
No it wont even rev out, we had to spray starting fluid into the carb to get it to run.So my guess is a clogged jet.We will be taking the carb off here soon and giving it a whole cleandown.
