How is the Bolt Pattern Measured on a Rim?
Old Jan 17, 2006 | 09:43 AM
RaptorOwner's Avatar
Default How is the Bolt Pattern Measured on a Rim?
I have a rim that the bolt holes measures straight across center to center at 5 and 5/8 of an inch and cant figure out what it fits??
Any help would be greatly appreciated.
Old Jan 17, 2006 | 01:57 PM
skyharborcowboy's Avatar
You best bet is to either call a rim MFG or look up some online catalogs to see what it matches.
Joe
Old Jan 17, 2006 | 04:36 PM
witti's Avatar
http://michigandirtslingers.com/ATV_Tire_Chart.htm
Shows how to measure and each atvs size.
Old Jan 17, 2006 | 04:42 PM
hondabuster's Avatar
Its gonna be metric, if its for a quad.
5.625 is around 142.8mm, so its probably a 144mm rim. The fronts on the honda sport quads are 4x144. So was the cannondale front. And the newer suzuki quad sports use it too (400 and 250).
Whats the diameter of the rim?
Old Jan 17, 2006 | 08:59 PM
Well 4/143 is the size of bolt pattern for a Bombardier and this is the same bolt pattern then. So is there anything else this will fit?
Old Jan 18, 2006 | 04:46 PM
witti's Avatar
Use the link/address I previously posted. It gives most atv bolt pattern and tire/rim sizes.
Joe454
Nov 20, 2020 01:19 PM
blueandy88
Sep 7, 2020 03:11 PM
EIF
Apr 20, 2017 07:15 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
blueandy88
Aug 30, 2015 08:26 PM
