Drz400 base gasket?
Old Jan 21, 2006 | 08:44 PM
660Rryder's Avatar
Default Drz400 base gasket?
I have been reading about the drz base gasket mod for a z400. What is it? How much is it? Is it worth it?
Old Jan 21, 2006 | 10:23 PM
garrett5462's Avatar
the DRZe dirtbike has practially the same base gasket as the z400, so if you put a DRZe (yes, there is an e) base gasket on the z400 instead of the stock z400 one, it will raise your compression from 11.2 to 12.1. The DRZe base gasket is thinner so it dros the head down a slight bit which boosts the compression.
EIF
Apr 20, 2017 07:15 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
