Cracked Eiger rear diff.
Old Jan 24, 2006 | 07:43 PM
Eiger23's Avatar
Default Cracked Eiger rear diff.
I think that I have developed a small crack on the fill hole for the rear differential. I believe this is the cause of my leaking fluid. So, first off could fluid make it through a crack that is above the fluid full level? And, also, is there any way to either seal this, or replace just half of the differential case? After being quoted $700 for a new rear end, I hope there is some alternative. Thanks.
Old Jan 27, 2006 | 09:50 PM
teven's Avatar
are you sure its cracked, cus mine has small lines that look like cracks, that are from the mold it was pressed in.
Old Jan 28, 2006 | 12:51 AM
GrnXnham's Avatar
Yes, fluid WILL leak out of a crack above the full level.
Old Jan 28, 2006 | 01:22 AM
hondabuster's Avatar
If you clean it really good, with scotchbrite pads, and wipe it clean with acetone, you could apply some JB Weld.
Old Jan 28, 2006 | 01:36 AM
aksafari's Avatar
Yep, a good epoxy might seal the crack, but WHY is there a crack??? If the crack is from stress, NOT a factory defect, then it's a good bet the crack will grow, ruining the epoxy seal. Make a little scratch mark where you think the crack ends, then ride for a while. If the crack is growing, no epoxy is going to help.
I'd say remove your diff, dissasemble to the case, and have it welded for $25. Then, your problem will be solved.
Old Jan 30, 2006 | 06:32 PM
Eigeraholic's Avatar
Do you think it was caused by overtightening? I'd say that welding is the only way to go.
Old Feb 1, 2006 | 10:39 AM
sliver's Avatar
My eiger has a crack in the same place! It cracked when I was tightening the plug, I think it is a weak spot in the design because I was using a small Allen key and wasn't torqueing the hell out of it. Oil in the threads can build hydraulic pressure add a weak design and you have why it happened. I've used a liquid seal but it is only a temporary fix, I'm going to either JB Weld it or tear it apart and get it welded.
mywifesquad
8
Sep 21, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
Slagpolaris
Sep 5, 2015 09:41 PM
