z250 power upgrade
Old Jan 30, 2006 | 07:32 PM
3QUADS's Avatar
Default z250 power upgrade
I am trying to give my son's z250 more power in the corners.It has a yoshi pipe ,jets ,k&n filter.What other options are out there.My son is 11 years old and not big enough for the z400. Would going to a smaller rear tire help. Thanks for any help
Old Jan 30, 2006 | 07:48 PM
suzukirider55832's Avatar
smaller tires would help out your acceleration a bit but he would lose top speed, maybe you should just go with a full system pipe, intake, jets, web cam, magura hydraulic clutch kit, and a wiseco piston as soon as they come out with it...read my post called z250s and there is a guy who has a web cam in his z250 and he has all the info you'll need to order one and everything...
Old Jan 30, 2006 | 11:37 PM
IRideAZ250's Avatar
Like he said, read that z250 thread. It may take a while, but read the whole thing and you'll come away with a good bit of information.
Old Jan 31, 2006 | 04:55 PM
oh and also, go with some razr rear tires and razr 2 tires...i'd just keep it at stock heighth though
Old Jan 31, 2006 | 05:26 PM
thorrider250's Avatar
gettin all that stuff would be pretty expensive. id start off with a pipe and jet kit. that helped mine out alot. i also noticed a great differnece when i got the razrs. smaller tires would help out the bottom end power a little too. you prolly want to know what pipe. i have a white bros E2 pipe and love it. i also hear that the yoshimura pipes are pretty good. check out rockymountainatv.com
Old Jan 31, 2006 | 05:29 PM
sorry, just realized you said you had that stuff. smaller tires will help with accel, so will the manual clutch.
Old Jan 31, 2006 | 06:11 PM
3QUADS's Avatar
I found holeshot mxr tires 18-10-8 have you heard about them.
Old Jan 31, 2006 | 07:38 PM
mxr4's are pretty much motocross only tires...they're 2 ply so they're not very puncture resistant and they are veeery soft so they will wear very fast so if i were you i'd go razr rears and razr 2 fronts..don't go razr 2 rears because z250s aren't very powerful and the razr 2s have veeeery big sidewallls and so if he tries to whip it around it may roll so razr rears and either razr or razr 2 fronts...i'm gonna go razr2 for fronts because they are very good fro trails and that's what i ride most...and like i said read the z250s post and there is a lot of info about what some people have done with thier z250s and thay can outrun stock warriors and modded 300exs...go full system, or just keep the yosh slip on, but you will gain a lot more power with a big gun evo x full system or pro circuit T-4 silencer with the pro circuit header, web cam and springs will get you a looooot of power, a magura hydraulic clutch, and a high compression piston will get your sons z250 a lot more power...good luck...
Old Jan 31, 2006 | 07:49 PM
oh and also, take off teh air box lid and you'll get a gain in power...you might have to go up a size in the main jet or so, but it'll be worth it with the gain of power that you'll get...your air filter will get dirtier quicker so buy an outerwear for the k and n ( maybe 10 bucks or so?) and then get about 2 of your wifes pantyhose and put it over the air box where the air box lid would go and then you'll still have suffecient power gains while still having a clean air filter...the pantyhose thing sounds weird but it will actually work!...and then when you go to clean the air filter just stick a new layer or 2 on the air box kid and you're good to go!
2quiker
Mar 22, 2022 08:36 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Brandon400
Sep 5, 2015 08:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
