Leaky two stroke pipes
Old Feb 10, 2006 | 02:47 PM
lottery's Avatar
Default Leaky two stroke pipes
Hi....Is there any thing you can do about the oil leak that two stoke pipes have. Mine leaks at the flange and then down on the cases of the motor. I have replaced the pipe, gasket and even put high temp gasket maker there and it still leaks. Its leaking between the flange and the cylinder...
Thanks....By the way I run 32 to 1 mix amsoil dominator two stroke oil...
Other then that the bike is great....
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
