Ozark question
Old Feb 10, 2006 | 11:08 PM
WolverineMan15666's Avatar
Default Ozark question
My daughter has an Ozark. I've noticed that the front wheels have a little slop in them. I'm not sure if I need to replace the front wheel bearings or if this slop is normal. My wife has a Recon and it always did have a little slop since it was new. I've also noticed that the Honda 90s have a little slop even when they are new. So......my question is.......do the new Ozark owners have some slight movement in their front wheels or do I need to replace bearings?
Old Feb 11, 2006 | 11:32 AM
Ozark38's Avatar
Most likely it needs new wheel bearings. I had one side that had slop when the other side had none so I replaced them. Not saying you can't ride it like that but keep an eye on them cause they will get worse. One thing I noticed with mine was the wheel alignment was toe-ed in over an inch from the factory. Don't know if that was the cause but it sure didn't help it.
Old Feb 11, 2006 | 11:03 PM
10000's Avatar
i have one and i had the same problem. i replaced the wheel bearings and it stopped it.
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
clscott84
Sep 21, 2015 10:16 AM
