lowering the z for the ice
Old Feb 22, 2006 | 08:53 PM
yamahawarriormods's Avatar
Default lowering the z for the ice
okay one last thing the races are this weekend...i got a used lowering kit installed it.... now should i stiffen up the suspension it wasnt tippy at all last weekend but i heard my back tires were coming off the ground so any tips would be great last week i had my suspension totally loose......but i am woundering if stiffing it up would give me a little more bite.... plus the airfilter clamped to the carb did make a difference thanks for all the help soo far
Old Feb 22, 2006 | 10:08 PM
GITRDUN's Avatar
If your back left tire is lifting going into the corner, stiffen up the right front spring. This will help to keep the weight from shifting too much onto the right front wheel thus taking weight away from the left rear.
Old Feb 23, 2006 | 02:14 AM
s9195's Avatar
GITRON is right, stiffening the right front shock should help bringing the left rear tire closer to the ground for traction. We use a durablue sway bar for TT racing on our race quads. They really help in distributing the weight on the tires and really helping control rolling. Also, not sure on your riding style, but we completly come off the seat and practically sit on the inside rear fenders on the turns to help keep the tires flat in the turns. I see a lot of people trying to just spin the tires loose into the turns and end up loosing a gear coming out of the turns.
here's some links to picts of my boys leaning during races last year.
http://www.photoreflect.com/scripts/...um=0&adjust=-1
You will also find that playing with airpresure will help in traction if you find you're blowing up tires or getting to much traction. We usually will run around 2-5 pounds on the rear outside tires and about 4-10 on the inside tires for TT racing with holeshot tires depending on track conditions.
Glad to hear the UNI filter worked well for you.
Old Feb 23, 2006 | 09:58 PM
thanks i shall try it you guys are great.... we race like a street course on the ice but i think flat track racing is my new favorite thing thanks again and i will let u know how this weekend goes
Old Feb 24, 2006 | 06:16 AM
  #15
tlronny's Avatar
Lowered Z
I use CFM Performance stuff which is a bit cheaper but works well
CFM
Old Feb 24, 2006 | 03:31 PM
  #16
that thing looks mint what do u use that for
Old Feb 25, 2006 | 11:14 PM
  #17
tlronny's Avatar
Speedway
Flat track
Tarmac
Trail riding
Old Feb 26, 2006 | 11:02 AM
  #18
kawiking's Avatar
can u post a picture of your filter to carb mod. ive been wanting to do this for awhile but havent figured out how i wanted to do it. the shock mount seems to be in the way. would love to see how you over came it. thanks.
Old Feb 27, 2006 | 11:45 AM
  #19
i was easy i ordered a uni filter from dennis kirk with a 2 1/4 inch diameter were it connectes to the carb it is also 5 inches long it is a tight fit but works well i paid 22.00 for the filter and that included shipping
Old Feb 27, 2006 | 12:24 PM
  #20
kawiking's Avatar
thanks i'll check it out , do you like the uni better than a k@n?
