Help With An 05' KingQuad
Old Feb 22, 2006 | 01:45 AM
RedGoblin's Avatar
Default Help With An 05' KingQuad
Dalton is about $120, EPI is about $200.
Old Feb 22, 2006 | 02:16 AM
DavAsh's Avatar
LKGRenegade22,
I put the EPI kit in myself with the wet springs and it is the best bang for the buck mod i have donre to this point. How far are you from Charlotte? When I was looking for a Dyno center I found one just out side of Charlotte. I cannot think of the name of it at the moment. What cities are you close to? What pipe are you going to run?
The stock clutch does an OK job if you are interested in stock. The after market kits will help to remove any slip, improve the shifting , improve the engine breaking, improve rideability, Give you better low end power, and with the EPI kit and the wet springs it will increase the stall speed of the clutch and get the king into its power band much faster. I hope this helps and if there is any thing that RedGoblin or myself missed just let us know and one of us will try to answer, even if we have to make up an answer.[img]i/expressions/face-icon-small-happy.gif[/img] Just kidding!
Thanks
David
Old Feb 22, 2006 | 02:35 AM
LKGRenegade22's Avatar
I am about 3.5-4 hours from Charlotte. I have a 700rwhp corvette so I know where alot of places are with car dynojets but none with an atv dyno. I am assuming that you dont use the same? I live near Roanoke Rapids if you have ever heard of that. Where can I get the clutch kit and how much is it? One of my best friends is an ATV mechanic so I know he can install it with no problems but I need some help finding the right part numbers and all. Please let me know. THANKS!
Old Feb 22, 2006 | 02:44 AM
DavAsh's Avatar
So you are out in the middle of the state? I lived in Charlotte for about 5 yearsbut i am not very good about other parts of the state.
What size tires are you going to be running? What is the elivation you live and ride at? These are two question that you will need to answer before you order a kit. I got mine from my dealer for $170 for the EPI kit. Some guys are having trouble getting the inner clutch gasket to do the EPI kit. My bike was almost new andI did not need to reoplace the gasket. If you are looking for a big tire kit you can look at the High Lifter site and there kits. they are made by EPI and come with the gasket. They do not offer a stock tire kit, they only offer an oversized and extreme kit. Unless you are into a lot of mudd or run 27-28 inch tires I would suggest the stock tire kit. You get all the gains and only lose about 1-2 mph off the top speed. With the bigger tire kits you will lose more top speed. Private message me if you want the contact info for my dealer.
Old Feb 22, 2006 | 03:11 AM
  #15
I have a set of 27" Kenda Executioners on my KQ. The Elevation is right around 200 feet ASL where I live. I live in the northeast portion of NC right off I-95 about 2-3 miles from the VA border.
Old Feb 22, 2006 | 08:39 PM
  #16
redfishdaddy's Avatar
Could his problem with the King be associated with the ECM or the Cold Weather Mod thats available through the dealer?
Old Feb 22, 2006 | 10:30 PM
  #17
I wish I knew. I am going to investigate it more tomorrow when I am off. Can you tell me more about what you are referring too? My KQ did this with the weather about 55 degrees so I doubt it is a cold starting issue. I guess it has to be something with the ECM. I am debating putting the stock pipe back on and seeing if it takes care of itself.
Old Feb 23, 2006 | 01:25 AM
  #18
DavAsh's Avatar
If I were abetting man I would bet you need to change your spark plug. It is a cheep try and see fix and it would not hurt to do it anyway.
Thanks
David
Old Feb 23, 2006 | 02:05 AM
  #19
Thanks
David
I bought both the NGK CR7E and CR6E plugs the other day and I am going to take out the stock one later today and look at it then replace it with either the a new stock plug or the one that is 1 step colder. If that fixes the problem I will be the happiest person on earth tomorrow! I hate to take of the HMF pipe because it does give it quite a kick in the power area and it sounds awesome to me.
Old Feb 23, 2006 | 02:31 AM
  #20
DavAsh's Avatar
I hope that takes care of it for you.
