2003 Z-400 t-chain
Old Feb 21, 2006 | 01:14 PM
chili3's Avatar
Default 2003 Z-400 t-chain
I just bought a 03 Z-400, I here alot about the t-chain going bad. What is the best way to check the chain? We are going to Glamis in two week,s I would like to make sure it is ok before we go.
Old Feb 21, 2006 | 08:49 PM
mucky's Avatar
stock chains do stretch a lot if its been riden alot and hard. if its going bad you will know it because you will hear it rattle
the only way to really tell is to remove it but if you do that you might as well replace it
Old Feb 22, 2006 | 08:13 PM
witti's Avatar
You can check the chain by removing the adjuster checking how far out it is.
The adjuster is on the rr side of the cyll. Remove the bolt and spring from the center. Then remove the upper and lower bolts. Pull the tensioner straight out. Count the number of clicks left before the plunger is all of the way out. If its not all the way out it should be ok.
I replaced mine when there was only 2 clicks left.
If you need more clarification let me know.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
