z400 blowing blue smoke
Old Feb 27, 2006 | 03:39 AM
Exrider22's Avatar
Default z400 blowing blue smoke
the other day my friend and i where cleaning my carb, when we finished we started it it up and noticed that when i revved it and released it{de-acceleration} it blowed a little blue smoke. any ideas on what it can be Valves, rings; Or running to rich? plus i had the delership change the oil when i got it fixed for the corrosion problem, could it be that they used a diff. type of oil or too much. Thanks ahead of time.
Old Feb 27, 2006 | 07:31 AM
z838mx's Avatar
On de accelaration its usually the valve seals or seats. on accelaration its usually rings. And blue is oil and white is water burning.
Old Feb 27, 2006 | 03:35 PM
s9195's Avatar
z838mz is correct, it's your seals/seats. I found this past year that while racing my Z400 w/out any sort of baffel I'd go though the seals. Just a common thing. Same thing goes on Harley's when running pipes w/no baffel's, you'll go through head gaskets since there is no back pressure. But it sounds great - with an eventual expense...
I'd have your motor builder look into it before your next racing series because you're loosing some hp.
Old Feb 27, 2006 | 08:13 PM
Exrider22's Avatar
you think i should get this problem taken care of right away or is it not that serious?
Old Feb 27, 2006 | 08:24 PM
z838mx's Avatar
you should always take care of issues with your machine its part of maintaince on your atv if you put it off you may run into other problems down the road that may cause more damage not nessaraly the case with this but who knows why its doing this you wont know untill its apart and you can properlly diagnose the problem correctly.
Old Feb 27, 2006 | 08:28 PM
Exrider22's Avatar
yeah i guess ill call the dealership tomorrow, maybe ill be lucky to get it done under warranty. It sucks though beacuse i was w/out it for over a month dealing with the corrosion problem and now it looks like ill be quadless for awile again.......[img]i/expressions/face-icon-small-mad.gif[/img] my brother told me not to worry about it but i dont want it in the back of my mind all riding season.
Old Mar 7, 2006 | 09:04 PM
charliemurphy's Avatar
hey man, about that corrosion problem, checkout this thread.
http://forums.atvconnection.com/mess...did/484125.cfm
Old Mar 8, 2006 | 03:05 AM
Exrider22's Avatar
yeah i got that fixed, might of been to late though[img]i/expressions/face-icon-small-blush.gif[/img]
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bvolks
Sep 13, 2015 12:57 PM
