Any performance increase with new air filter?
Old Mar 9, 2006 | 04:20 PM
Pastor's Avatar
Default Any performance increase with new air filter?
I am getting a uni for my K.Q. Are there any performance increase with the filter?
Old Mar 9, 2006 | 05:39 PM
SuperSuzuki4's Avatar
You wont get much at all but going to a different foam filter. A k&n with a outerwear will give you some more. Also air box mods will give you more flow. I dont know if the KQs efi will adjust for more air flow. You may need a dobeck or power commander. A new filter and exhaust or just remove the spark arrestor will help quite a bit.
Old Mar 9, 2006 | 08:21 PM
DavAsh's Avatar
SuperSuzuki4,
By the time you add the foam around the K&N how do you say it gives more than a Twin Air or Uni? Are you recommending these mods from experience on your own King Quad?
Pastor,
If you are worried agout power gains, why are you doing the UNI? If you only want to get the stock filter out of the bikes then the UNI is good enough. There is no way the Uni cage will flow as well as the Twin Air. Just my 2 cents.
Old Mar 10, 2006 | 09:06 AM
The outerwear is not foam. The K&N with the outerwear will flow more air than any foam filter. I have used both kinds in years past. I dont have a KQ but I do have a raptor 700 and a Vinson.
Old Mar 10, 2006 | 12:55 PM
DavAsh's Avatar
What is the outer wear made of?
Old Mar 10, 2006 | 11:03 PM
Nylon I think. Go to outwewears website and look at them. I think it is www.outerwears.com
Old Mar 11, 2006 | 12:15 AM
1tonchev's Avatar
Uni, Twin Air, and K & N will all flow way more air than your engine needs or can use. I installed a UNI on mine, and did not notice any gains. The real question is how much dirt do you want to stop. K & N's marketing gimmick is that they flow more air than the competition, which they probably do, but at the sacrafice of letting more dirt through.
Old Mar 11, 2006 | 12:23 AM
CBF2's Avatar
Could not have said it better
+1
Old Mar 11, 2006 | 02:32 AM
DavAsh's Avatar
Thanks, enough said.
Old Mar 11, 2006 | 06:31 PM
Toyeboy's Avatar
I put on the Uni after having the stock filter for 7 months, and it opened it up seems a bit louder and breathes easier and NO dirt has gotten in since I've put on the Uni, I'd recommend in a second.
