PLEASE HELP!!!!!!!!!!!!!!
alright....i was out ridin today and when i stoped for a brake i noticed there was tranny fluid all over the tranny by the sprocket....it was whiteish....but when i rode it home and washed it(it was very muddy) i rode it up and down the road and nothin....no leaks.....do you think it could have over heated?
Yup, somehow you got water/moisture in your low end... I'd drain it completely, take off the cover, inspect for cracks etc, and clean out all the grey crap... it'll only keep building up... You may have either a cracked case inwhich some JBWeld would be a quick fix or a bad gasket.. which will need to be changed anyways as soon as you remove the cover...
Hope it works out for you....
Grey low end oil is never good.
well ive never ridin in water with it.i talked to my uncle and he said that theres a crack in the cylinder leting water escape.now i got to take the cylinder off and check.and im only 14!!!lol.well is there any thing i should look out for? ied apreciate any help.
I had that happen last year with my RM125 last year and it cost me a whole new cyl head. My son had heated the motor up so bad that the water ports had warped and the coolant went into the cylinder though, not the low end.
I was told never to use that Bars stop leak stuff they sell for cars in an ATV motor since the ports are way smaller then in a car.
I hate to say it but you've got to get your hands dirty....
well i got it apart and located the problem.the gasket under the cylender conecting it to the jug had dirt under it where the antifreez goes so you can see that it was leacking.im gonna order new gaskets.and by the way does anyone know the tourque specs are for the head and cyleender bolts?
and madmad you were right it was easy!
thanks for all of your help guys.
