Fixing a gas tank leak
Old Mar 19, 2006 | 10:17 PM
YamRap's Avatar
Default Fixing a gas tank leak
The gas tank on my 89 zilla is leaking. I don't have the plasitcs off yet, but it looks like something has worn a hole in the top of the tank, or it is leaking from the place where the gas goes in. If there is a hole, what will stop the leak and hold? Fiberglass? Any other suggestions, I don't really want to buy and install a whole new tank.
Old Mar 20, 2006 | 12:28 AM
quadguy1470's Avatar
I don't know for sure that it would work, but I've seen an epoxy putty that comes in two parts that you kneed together into a uniform color then within minutes it starts to get warm it will be too hard to work with within about 7-10 minutes. I know it has a resistance to chemicals because where I first saw it being used was on a steel drum containg paint thinner. It's gotta be woth trying. I'm not quite sure where to get it though. I believe the package says "poxy-putty" on it which was a brand that I used to see at my local swimming pool store, hope this is helpful to you.
Old Mar 20, 2006 | 10:33 PM
HillCrazy's Avatar
epoxy with chemical resistances would probly work. TIP- rough up the surface around the hole to help the epoxy bond.
Old Mar 21, 2006 | 12:11 AM
I did some checking today found out that the name of the epoxy putty i told you about is called nu-doh, I didn't do an online search for it yet but I'm sure it's available to purchase online. Sorry for the misinformation in my previous post.
Old Apr 2, 2006 | 03:42 PM
YamRap's Avatar
thanks for the help, i'll try to track some of that down.
Old Apr 5, 2006 | 12:24 AM
RUFFCOUNTRY's Avatar
I've used the epoxy on my truck it sticks to wet gas drys quick no problems
Old Apr 5, 2006 | 01:02 AM
Sparky8370's Avatar
I'd try duct tape. In all seriousness, I'd look on ebay for a used tank. You could probably jerry-rig it for a while, but that quad has a lot of vibration anyway nevermind jumps, whoops, wheelies, etc. Probably the same tank as a 250.
greg74
Sep 10, 2019 03:03 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Derek Allen
Jul 22, 2015 09:25 PM
traumajunkie
Jul 5, 2015 03:03 PM
