does drilling a hole in the airbox help?
Old Mar 20, 2006 | 08:52 PM
SuzukiRider21's Avatar
Default does drilling a hole in the airbox help?
Old Mar 20, 2006 | 09:39 PM
CBF2's Avatar
How about some more info/what bike/what you are trying to accomplish?
Old Mar 20, 2006 | 10:06 PM
velocyraptor's Avatar
it doesnt matter what quad, the more air the filter is exposed to, more air flow there is available to suck in
yes, drilling a hole in the box will help, but one wont make alot of difference but several holes will
Old Mar 20, 2006 | 10:09 PM
5spdvinsn's Avatar
An increased flow of air in may improve the power somewhat, but if the air can't escape as fast as it can go in, the power won't increase much. And i beleive that the carbs may need to be rejetted to compensate for the increased air flow.
Old Mar 20, 2006 | 10:53 PM
CBF2's Avatar
One sure will make a difference if it is 6" diameter, if it is 1/8" diameter it won't matter.
All you will do is let in more dirt & screw up your throttle responce unless you rejet & DEPENDING ON THE QUAD get an exhaust. See why we need more info.
Old Mar 21, 2006 | 10:33 AM
quadguy1470's Avatar
I drilled 5 holes 1" in diameter and installed "uni prefilters" installed an HMF utility series pipe and a Dynojet jet kit this combination was effective, however just the holes in the lid did not achieve much of a gain if any. You really need to consider a pipe and rejetting if you are going to mod your airbox. You can see the airbox mod I did in my pics, but I didn't have the pipe and jetkit on at the time.
Old Mar 21, 2006 | 12:46 PM
squeege's Avatar
I am currently running with the lid lifted with about 3/16" gap all around with a dyno jet kit and no pipe. It runs great, but soon I will do an airbox mod with unifilters or such so dirt has a less chance to damage the engine.
Old Mar 22, 2006 | 12:07 AM
MisterMom's Avatar
I'm not sure what you're riding but i have the air box removed and a steel plate for a bracket to replace the original fitting. Oil soaked foam filter with a filter sock over that. All 18 of the lt 500's i ride with have been like this for years. I'm not sure if this will work for your application but i hope it helped.
Old Mar 22, 2006 | 02:40 PM
squeege's Avatar
just modded my airbox see pics, I don't usually go in real deep water so it should work ok....
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
mbriggs
Sep 13, 2015 10:47 AM
toonces
Sep 5, 2015 01:14 PM
