lt-r 450
Old Apr 4, 2006 | 09:15 AM
wayfastwhitey's Avatar
Default lt-r 450
Just went out this weekend and bought a suzuki 450 and i ordered a cherry bomb but my question is where do you put it on the bike?
Old Apr 4, 2006 | 11:44 AM
LivinInVegas's Avatar
Default lt-r 450
If you look under the front headlight you will see a black plug covering a white female connector plug. I just took the light off as I won't use it anyway since this is my race bike. If you remove the light it's only one bolt and pull the light down towards the ground. this gives you better accesibility to the plug. Remove the black rubber cover and connect the cherry bomb. You will need to zip tie it up. Use two and they do not include the zip ties in the Yoshimura package like the instructions say they do! I just zip tied it to the wire harness in the towards the back just to protect it from rocks.
Then remove the airbox lid, remove the silencer inside the exhaust and you will have to remove the rear brake light to get the top bolt on the exhaust cap off. Pull out that silencer place it in your parts box because you'll never use it again, and reassemble the cap and your brake light. Use 91 or higher octane gas. You can add some race gas to boost the octane if needed. this will now sound and feel like a different bike.
Old Apr 4, 2006 | 11:50 AM
Default lt-r 450
besides yoshimura who else makes an exhaust for the suzuki 450
Old Apr 4, 2006 | 12:08 PM
Default lt-r 450
Trinity, DMC, Pro Circut, White Bros. I would stay with Yoshimura as they are really involved with Suzuki and build all their Team Suzuki exhaust and Doug Gust's and Jeremiah Jones engines. They really develop this product the best plus the fit and finish is right on. Just my two cents. I will buy this system after a few more months just like I waited with my bike to let them work out any first run issues.
Old Apr 4, 2006 | 12:14 PM
Default lt-r 450
this new suzuki is the most poweful, best handling, best flyin atv that i have ever rode and i have rode alot in my life
Old Apr 4, 2006 | 04:54 PM
thorrider250's Avatar
Default lt-r 450
have u guys seen the advertisements for the trinity stage 4 exhaust and EFI controller, its supposed to give 11 extra hp....i was surprised at the 7 that yoshi pipe and cherry bomb add. is the cherry bomb the same things as an EFI controller or what...cuz the cherry bomb is like 40 bucks and teh trinity EFI controller is like 200...whats the difference between teh two
Old Apr 4, 2006 | 05:43 PM
scagz's Avatar
Default lt-r 450
The cherry bomb is only too be used with no air lid and s/a (peashooter) removed from the stock pipe . If you go with a full system then you have too go with a different controller .
Old Apr 4, 2006 | 05:58 PM
scagz's Avatar
Default lt-r 450
Just go 2 LT-R450Central
YmeHP
Apr 4, 2007 10:30 AM
maxxedouty
Jan 7, 2007 12:33 PM
gis24
Nov 29, 2005 06:29 PM
