250 r help
Old Apr 9, 2006 | 02:06 AM
benzo's Avatar
Default 250 r help
hello all looked everywhere need to no compression for 250 r suzuki checked mine it is 100 thanks
Old Apr 9, 2006 | 02:13 AM
gassrx's Avatar
Default 250 r help
hows it run good ride it bad re ring it i run about 147psi head mods
Old Apr 9, 2006 | 02:20 AM
benzo's Avatar
Default 250 r help
it ran great till my buddy wrecked it and the engine reved wide open for about a minute now it wont start bear with me im new to atvs but i no the basics i got spark fuel no start so you saying its compression?checked the piston its fine rings, and reeds all fine were to next??? thanks
Old Apr 9, 2006 | 02:29 AM
benzo's Avatar
Default 250 r help
so you advise new rings???thx
Old Apr 9, 2006 | 02:30 AM
gassrx's Avatar
Default 250 r help
did the timeing slip check the key way,on the stater
Old Apr 9, 2006 | 02:32 AM
benzo's Avatar
Default 250 r help
what should i look for on the keyway??
Old Apr 9, 2006 | 02:44 AM
benzo's Avatar
Default 250 r help
thx for the link but my question was how can i tell if something is wrong newbee ?
Old Apr 9, 2006 | 02:50 AM
benzo's Avatar
Default 250 r help
where exactly is the stater and its purpose ? how do i check it? thanks
Old Apr 9, 2006 | 03:49 AM
gassrx's Avatar
Default 250 r help
remove the stater cover , remov lock nut the key way will be twisted.,, sorry it is on the end of the crank shaft. some times called the flywheel
