CAN SOMEONE PLEASE HELP,IM LOST
Old Apr 8, 2006 | 04:33 PM
redneckfromnb's Avatar
Default CAN SOMEONE PLEASE HELP,IM LOST
ive got 3 post here and only 1 response,i know there are alot of pros here,they have helped before.i got a 1986 lt 250 quadrunner and it keeps missing if you hold the throttle at a fast idle or more.it works better if you just ease it up faster more slowly.any ideas.
Old Apr 8, 2006 | 07:00 PM
MotoF150's Avatar
low compression, dirty carb, restricted fuel shutoff valve, main jet, intake leak, restricted air filter, bad gas
Old Apr 8, 2006 | 09:31 PM
thanks for the reply,i put in a new head and base gasket
Old Apr 8, 2006 | 10:19 PM
IdahoVinnie's Avatar
Did the problem start before or after you replaced the head and base gasket?
If it was after, then why did you replace them?
Just trying to get more info.
Could also be bad spark plug, or insufficient spark.
Old Apr 9, 2006 | 09:03 AM
i replaced the head gasket because the base gasket was leaking oil.the 2 ront head bolts were loose.
lonerider856
Oct 13, 2023 03:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
bvolks
Sep 13, 2015 12:57 PM
bigbear350quad
Sep 11, 2015 12:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
