Z400 Question
Old Apr 12, 2006 | 09:09 PM
Z40005BR's Avatar
Default Z400 Question
Does anyone know how often to check and adjust the valves?? If so how do you do it and is it worth doing myself or do I need to take it to the shop like if its a 9 or 10 on the scale ill take it there, otherwise tell me how to do it
Old Apr 12, 2006 | 10:47 PM
mucky's Avatar
I was told between 6/12 months to readjust. I never did mine for 2 years and never had a problem. but its good to have them checked
to make sure if they need it. you have to buy a shim kit to adjust the valves. and a normal kit runs around $80 and it has around 100+
shims in it. if you have never done it then it can take awhile. on a scale from 1-10 and 10 is the hardest I would give it a 7.
it took me 45min to adjust my valves and I had the head off and the cams loose on the table when I was rebuilding.
so it can take awhile. you have to measure the valve lash and then see what the specs are and then you look at the chart in the service manual
to see what size the shim is to install for that valve. once both valves a re done install the cam and turn it to get the oil out between the shims and then you measure again. if its not in specs then you start over again that why it can take time to do it. good luck Mucky
Old Apr 13, 2006 | 04:15 PM
Z40005BR's Avatar
Thanks
Old Apr 13, 2006 | 10:20 PM
kawiking's Avatar
p.m oscar660, he just did my valves last week. i went down to a atv repair shop and just asked for the shims , you dont need to buy a whole kit.
Old Apr 16, 2006 | 09:56 PM
mucky's Avatar
if you know what shims you need you can buy just those instead of the whole kit like what was said before.
I got the kit so if I have a problem I dont have to see if somebody have the right size
Old Apr 17, 2006 | 02:35 PM
Z40005BR's Avatar
are the shims those cheap metal things that you can get at napa?
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
