HAVE I GOT THE PLAGUE
Originally posted by: redneckfromnb
(1)i got va 1986 lt 250,it will turn over great on the starter but wont even kick,pull the cord ant it starts.
(2)the fuel pump dont have much suction,im wondering if one from a older skidoo will work(i have a new one)there both vacm operated.will it work if i gravity feed the fuel?
(2) I don't know about the interchangability of the fuel pumps. I would think that if it could run without a fuel pump, then the manufacturer wouln not have originally installed one. If your 250 will run fine (even though you have to pull start it), then why do you feel that you need to replace the fuel pump?
Let us know...
(Now we're awaiting your response!) [img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
well for starters i have been boosting from my carand the reason for replacing the fuel pump is it hardly spits any fuel.the engine turns over hard.anyone know how many ohms the stator shoulh have,i had to relace mine with a used one
I'll be more than happy to help you the best that I can, but I need accurate info, and more info.
In your first post of your troubles, you said that "it will turn over great on the starter". In your last post, you said "the engine turns over hard". My guess is that your atv battery is quite low on a charge, and even though you are jumping it, the atv battery is absorbing much of the voltage from the car battery, and not allowing enough voltage to be provided to the starter and ignition system.
Try this. Disconnect the positive cable from the atv battery. Carefully connect the positive jumper cable to that disconnected cable. Connect the negative jumper to the negative atv cable. This bypasses the atv battery completely. Does it start now?
Also, do you have (or can you borrow) a voltmeter?
Without specific answers, all we can do is guess as to the nature of your problem.
to start with i dont know why i said it turns over hard,i eliminated the atv battery any hooked directly to the car.the engine still wont startoff the starter,yes i own a digital voltmeter.i even hooked up another tank on the rack so it will gravity feed.on the pull cord it starts and runs for about a minute.where am i going wrong?
HELP
HELP
#15
You have 2 problems, probably unrelated to each other.
While jumping from the car battery (and cranking the atv engine), take a volt reading. Connect the negative voltmeter lead directly to the engine. Connect the positive lead to the "hot" connection of the starter. What is the reading?
#16
i want to thank you idaho vinnie for the help,ive been working long days lately and i wont be able to get to the bike till saturday,i will do what you suggested and post my findings if you want to keep checking.your help is very much appreciated.
#18
GOOD NEWS I FINALLY GOT IT GOING.i still need to set the valves and it seems to be lugging.the electric start is working now,i switched plugs from ngk to champion.it seems to be holding a charge,i got a car battery hooked up and its reading 14.2 volts even with the lights on.can anyone tell me what the valves should be set at,also what the settings for the carb would be.again thanks for all your help.
Coryco
8
Jan 30, 2015 06:19 PM
