z 400 carb ???
Old May 4, 2006 | 09:16 PM
660Rryder's Avatar
Default z 400 carb ???
I was wondering what is the best carb setup for my z... I was thinking a used yfz carb... Or a R carb... Would a rmz450 bike carb work any good??? Any help would be good. Thanks...
Old May 5, 2006 | 12:44 PM
s9195's Avatar
I was told to go with a 39-41 FCR flat slide on the Z's that have motor work done/high comp pistons. Look for a 02-03 or 06 CRF. I've heard of people being able to use certain YZF carb's also on their Z's but had to make some modifications. A few people on this forum helped me with that.
Since I've gone to the anthena head/piston I went with the 41 mil fcr myself.
Old May 5, 2006 | 09:12 PM
mucky's Avatar
I run a 41mm FCR and its great. I know where to get a new one but its not cheap. around $500 or more for it
look around you'll find something that will work for a lot less money
Old May 5, 2006 | 10:20 PM
BlackKawi400's Avatar
The cheapest route is to look on ebay for a YFZ 39mm Carb or something similar. These can be picked up for around $200-250
I picked up a 41mm Sudco Racing FCR for $250.
Another route is to go with a 40mm FCR from Service Honda.
1. Carb: 16100-MEB-771 (www.servicehonda.com) $370
2. Throttle Cable: Part # 07-0774 Motion Pro control cable FCR to stock LTZ Throttle - $34.95 Carb Parts Warehouse - (216) 635-1099
Also, be advised you need to run the fuel petcock on prime and plug the vaccum hole for an FCR.
Old May 6, 2006 | 02:44 AM
kawiking's Avatar
why do you say that black kawi(petcock on prime and plug vac. hose)?????
i run a 39mm 04' yfz carb - i got it off e-bay for $150!!!!
s9195 have you got you z-400 together(athena) - does it rock??!!!!
Old May 6, 2006 | 04:39 AM
The stock carb uses the vacuum line to open the petcock for fuel, the FCR's dont have a vacuum port for that. You have to run it on prime, otherwise you won't get fuel.
How are you running yours?
Old May 6, 2006 | 04:27 PM
mucky's Avatar
my FCR is hooked up the same way as stock and it works great
I dont use the prime setting
Old May 6, 2006 | 05:23 PM
SuzukiDoug's Avatar
450R carb is the way to go!
Old May 6, 2006 | 05:59 PM
What line do you run to the petcock for vaccum????
Old May 7, 2006 | 09:06 PM
mucky's Avatar
its hooked up to the port just below the choke lever
I have a 41mm FCR flat slide racing carb, tried to find a pic of it but no luck
