Hot Cams ????
Old May 4, 2006 | 11:11 PM
HillCrazy's Avatar
Default Hot Cams ????
Does hot cams help low end or high and how much of a difference do they make? Also are they a pain to put in?
Old May 5, 2006 | 04:48 PM
TractorPacker's Avatar
Do you have a balloon?
There is 2 stages for the Z. One is for bottom end gain and the 2 is for over rev. The stage 2 is a good set of cams. They take a little bit of torque, but give a good amount of top end power. If you raise compression an install the stage 2's will really be happy. You can raise the compression .8 to 1 by getting the base gasket from the DRZ400 dirt bike.
Old May 5, 2006 | 09:06 PM
mucky's Avatar
stage 1 is intake cam only and it helps on low end only
stage 2 is both cams and it gives great mid to top end
its not hard to install a set but you do have to readjust valves in the process
and putting a base gasket of a DRZ helps
Old May 6, 2006 | 02:48 AM
kawiking's Avatar
go for the stage 2 !! you wont be sorry. if you go stage 1 you'll always wonder what the stage 2 is like.LOL!!!!
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
