2003 suzuki eiger timig
Old May 5, 2006 | 12:33 PM
stayonyourelbows's Avatar
Default 2003 suzuki eiger timig
Hello... Anybody ever had the head & cylinder jug off of a suzuki 2003 400cc 4x4 eiger? I have ring problems and need to
replace them. The disassembly and reassembly is not a problem, however there does not appear to be markings on the cam
gear to make sure the timing is correct. Also, is neccessary to pull the side casing, drive belt, drive and driven clutch to
see the crankshaft gear while timing? Or, can the piston be brought to TDC and set the gears and chain this way ???
Thanks
Chris
Old May 6, 2006 | 01:41 AM
aksafari's Avatar
Use a center punch and make your own marks. A quality punch will make marks in the hardest gears. Set for TDC on the compression stroke and make your marks...
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
Sep 1, 2015 11:59 PM
