doing away with oil injection system
Old May 14, 2006 | 01:04 AM
rheemac's Avatar
Default doing away with oil injection system
I own a suzuki LT 80 2004. Is it ok to do away with the oil injection and premix the gas?? if so, what ratio is recommended? Didn't know if this caused a problem with the carburetor?
Old May 14, 2006 | 11:17 AM
BigDimo2624's Avatar
yeah you could probably pre-mix, but im not absolutely positive. idk what ratio it would be
Old May 15, 2006 | 03:11 PM
gassrx's Avatar
run the 50:1 amsoil premix will take good care of the bike , you can read up on it on my two stroke porting page gassrx.com
Old May 22, 2006 | 04:15 PM
redneckfromnb's Avatar
yea you can premix your gas i have a 91 polaris trail boss and its a two stroke and i mix it and it runs fine
Old May 22, 2006 | 04:28 PM
Sparky8370's Avatar
I did it when I was younger, on a blaster. Somebody brought up a good point on here before. Didn't seem to make a difference with me though.If you go to pre-mix from injection, you'll have less gas going through the jets (displaced by oil) so you may become lean (air/fuel, not oil/fuel). I didn't quote, just para-phrased.
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
