lt 250r trouble starting HELP!!!!!!!!
Old May 20, 2006 | 07:58 AM
lt2strokerider's Avatar
Default lt 250r trouble starting HELP!!!!!!!!
what is an irriduim spark plug?
Old May 22, 2006 | 03:58 PM
redneckfromnb's Avatar
try using a champion plug because the ngk is just not a good plug for two strokes
Old May 22, 2006 | 04:48 PM
Sparky8370's Avatar
Originally posted by: jasonridin
Ok, little story here. Rebuilt the '87 lt 250r a while back, ran great after the complete rebuild. Until just a little while ago. Usually have to put a new plug in it when it's cold to get it to fire. When started, runs great jetting is spot on. FASSSST! If I shut it off for more than about 30 min. its back to a new plug before it will start again. I refuse to blame jetting, because nothing changed in that department when this problem arose. Also, the thing will sit there and idle smooth as silk for just as long as you'll let it. I was wondering about an ignition problem, weak but not completely faulty stator or coil?? Has anyone else ever run across this?? Need to aleiviate this problem to sell it if anyone is interested, bought the 06 ltz400. If anyone has any ideas please let me know.
Sick of working on the old LT and bought an 06 Z, sounds very familiar. What's your compression when it's cold versus when it's warmed up? With mine, I am blaming the carb. I can re-jet and adjust, then it seems I need to do it all over again everyday I ride it.
Old May 22, 2006 | 05:44 PM
jasonridin's Avatar
I'll check that, but it was just rebuilt. New piston, cylinder, and crankshaft less than 20 hours ago. I just think that takes out so much of that possiblility.
Old May 22, 2006 | 11:17 PM
  #15
gassrx's Avatar
dependining on riding still you need to rering the girl speicly with wiseco pistons i go about 15 hours max
Old May 24, 2006 | 10:54 PM
  #16
sblt500r's Avatar
its your ignition coil on the stator. its too week to burn the gas and oil on the wet plug. i would ohm out your stator to see what condition its in. also make sure to check the pick up coil(little back box on the stator.)
Old May 24, 2006 | 11:55 PM
  #17
jasonridin's Avatar
I take it you have experienced this same problem before?? I did ohm my stator windings and they didn't match the specs I had, but coming from an outboard motor background, I place very, very little faith in ohm readings. The only true way to know is with dva voltage output, but I have no specifications for that. My book also doesn't give values for the pickup coil. If you have encountered this same problem, I have no choice to take your advice, thanks man.
-Jason
Old May 27, 2006 | 10:33 PM
  #18
sblt500r's Avatar
heres the specs right from the suzuki manual. i don't have a fancy ohm meter, just a craftsman cheapy, and it works good for me. i've had alot of problems with stators, so i always check them first when the quad is running like crap. also the pick up coil is more prone to fail because of its location. it gets in more contact with water more than the others and rots out. if it is the pickup or any other coil i would suggest buying a complete ricky stator. that way your starting off brand new, and not repairing an original, with hard wires, or rusty conections.
Stator Test
Lighting 0.5-1.0 Ohm Wires Y/R & B/W
Source 315-475 Ohm WIres B/R & R/W
Pick up 175-265 Ohm Wires BL & B/W
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
joe blo2
Jun 7, 2015 10:54 AM
1000gade
May 27, 2015 12:37 PM
rking85
May 20, 2000 11:01 PM
atving
Nov 17, 1999 09:24 PM
