400 leaking problem
Old May 24, 2006 | 07:30 PM
Rickmaff's Avatar
Default 400 leaking problem
my kfx 400 is litteraly dripping fuel from somewhere in the carberator. i noticed this a few days ago and made sure i had the boot covers on the bike real tight. it drips fuel almost constantly when it is running. what do you think, should i take the carb off and tighten everything up or have it done by one of my friends who is a mechanic.
Old May 25, 2006 | 03:58 AM
s9195's Avatar
is the petcock on the PRI or ON postion when it leaks? Does it leak while the motor is off and in the PRI postiion? The ON postion is vacume feed and will only draw fuel as long as the motor is running. The PRI setting bypasses the vacume feed.
I'd pull the carb and check it, check all the fuel/vacume hoses, lines, intake boots, & choke line inlet to start with.
slowgsxr97
Mar 18, 2022 03:40 AM
Nondem
Feb 22, 2020 12:20 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Unzzy66
Jul 11, 2015 10:01 PM
traumajunkie
Jul 5, 2015 03:03 PM
