06 Eiger Snorkel
Old May 29, 2006 | 04:29 PM
TXMUDPIE's Avatar
Default 06 Eiger Snorkel
I have an 06 Eiger that I have installed a snorkel on. When I give it gas it bogs but if I cover half of the tube it runs like it did when I first got it. If I change the jet size will that eliminate my problem? If so what size jet should I buy. Thanks for the help.
Old May 29, 2006 | 10:40 PM
rolsmojave3's Avatar
Does it run better with the choke on also? If so you need to go up a jet size or 2...try a 127.5 and a 132...that'll get you set
Old Jun 5, 2006 | 07:09 PM
Bamaman81's Avatar
jet sizes are different with evey brand that you make.
when you snorkle a bike it changes the air fuel mixture therfore you need to rejet in order to compensate for the difference in the stock snorkle and new one. That is why when you put your hand over the end of the snorkle it is running better it is bring the air fuel mixture back to what your carb is already setup for. Also what size pipe did you use for you snokle cause if it is to big you wont even be able to rejet to compensate for the amount of air coming in.
Old Jun 5, 2006 | 08:01 PM
he'll be able to jet to any amount of air...the jets go waayyyy up there
Customer Service #1
May 15, 2020 08:46 AM
Steeldon
Sep 9, 2015 09:38 AM
Ean
Aug 20, 2015 07:13 AM
Cantbuytime
Aug 17, 2015 06:33 PM
baysport
Jul 23, 2015 11:37 AM
