gas for z400
Old Jun 9, 2006 | 11:04 PM
alwaysAz400rider's Avatar
Default gas for z400
is it alright to put premium in my piped jet and filtered z400 with out making any adjustments? or it not what needs to be adj'd?
Old Jun 10, 2006 | 04:02 AM
premium fuel that is. Does anyone know?........
Old Jun 10, 2006 | 11:24 AM
Z40005BR's Avatar
no you are ok...actually since you have those mods, you should have already been running it with the stuff...you will find your quad will run much better with premium
Old Jun 10, 2006 | 07:15 PM
BigDimo2624's Avatar
my small engines teacher is a highly experienced motorcycle mechanic, and he used to race. i asked him the same question before and he said that regular unleaded is the best. but its your money so do what you like! hahah. with these gas prices id be using unleaded anyways.
Old Jun 10, 2006 | 08:06 PM
Scooter86's Avatar
Knows Old ATV Questions!
As long as you haven't changed the compression or anything, running the minimum grade Suzuki recomends is still fine. Just putting a pipe and filter on does not mean you need to run premium. Chances are you will actually make a bit more power on the recommended grade.
Old Jun 11, 2006 | 10:32 AM
ss97's Avatar
Lets Ride!
My z400 has never had anything but 91-93 octane and after a year a a half the thing still runs perfect. Original plug and everything.
Using lower octane in a higher compression engine can cause your valves to need adjustment quicker. Octane regulates ignition and keeps timing level, lower octane in a higher compression engine can cause pre-detonation which can foul plugs and upset valve timing.
Any engine builder worth his salt will tell you when you get above 10 or 11:1 compression you should run super.
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
