z400 keeps blowing fuses
Old Jun 26, 2006 | 11:24 PM
joechum's Avatar
Default z400 keeps blowing fuses
one of my buddies has a z400 and he will start it up n it will run fine then it will blow a fuse n go completley dead and we cant seem to trace where its coming from anybody ever had this problem or heard of a fix
Old Jun 27, 2006 | 02:31 PM
gassrx's Avatar
one of the wires is shorting out , start it and move the wires around it will die , ohm test each wire is the best,or look for a burn mark on the harness, a ground wire broke will do it to
Old Jun 27, 2006 | 04:40 PM
zman420's Avatar
Look at all the wires CAREFULLY, i had a electrical problem that drove me nuts and i thought i looked over all the wiring, but i missed a worn through wire that was grounding out. it was probley from a tie-down hook that pinched the wires. Good luck
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
