Need help with LTZ400
My LTZ400's got a bit of a problem and i don't know what it could be.
It starts up ok, i warm up the engine with the choke on, then when the engine is warm i take off the choke.
I then put it in 1st gear and im off. It runs ok untill i approach a turning or have to slow down. As I approach the turning I pull in the clutch let go the accelerater and change down a gear or two, but everytime while im doing this my quad cuts out, and then is hard to start up again. It seems to cut out everytime I let go the accelerater for more than a few seconds.
I really don't know why it is doing this.
Any help greatly appreciated.
It sounds like you have a rich condition in your jetting. I had the same problem, I rejetted my carb and all was good. Have you ever rejetted, or did you move to a different elevation from where you bought your Z?
Your choke may be sticking open a bit, get yourself a pull choke and get rid of that thing on your clutch perch, check your spark plug for a fouled condition. You dont say where your from, but you shouldnt need the choke above about 70 degrees.
I noticed that you only have 10 post's on here. That make's me ask, Did you just get this quad? The reason I ask and it is embarasing is when I got mine I thought the P on the petcock of the carb ment primary. It actually mean's prime. And I was having the same problem. Hope it's that simple for you.[img]i/expressions/face-icon-small-happy.gif[/img] You may be flooding it.
Thanx to all of u for ur replies
Choney was right. I did move but the elevation did not change that much. I rejetted my carb and now it works just fine.
Well now i know that even if u move and ur elevation changes just a bit, rejet ur carb.
But thanx to all of u who replied.
Lou Domenech
Sep 11, 2015 06:35 PM
Jun 3, 2015 01:40 PM
90suzukiLT250s
Apr 5, 2006 11:29 AM
