LTR450 QUESTION - CHERRY BOMB VS EFI CONTROLLER
Old Jul 6, 2006 | 06:32 PM
RaptorOwner's Avatar
Default LTR450 QUESTION - CHERRY BOMB VS EFI CONTROLLER
Can someone tell me if both of these are needed or just the EFI controller itself? Why would you need both?
Old Jul 14, 2006 | 06:30 AM
Kracker's Avatar
The cherry bomb is meant to change the map to adjust for an aftermarket pipe, lid off. The PIM will adjust even more, for a pipe, lid off (or no box all together), an aftermarket intake and such. The controller itself will let you adjust(fine tune) the air/fuel mixture throughout the whole rpm range. I know I am not being very specific, but I hope this helps.
Here is mine.
Old Jul 14, 2006 | 10:01 AM
Thank you, your bike looks sweet.
What is that intake called and where can you get it?
Old Jul 14, 2006 | 09:54 PM
Kracker's Avatar
Thanks Raptorowner. Trinity seems to have the best one right now. Also, Pro design. You can get them strait from the companies themselves.
Old Jul 16, 2006 | 05:20 AM
DaBeechMan's Avatar
the FI dynatek lets you use their curves (comes with 3 one for stock, one for exhaust, and one for exhaust and intake) and the 4th curve lets you make a custom map. All curves are adjustable with the low, mid, high potentiameters.
if you are considering one they are great. i bought two and if you need one i have an extra
Old Jul 16, 2006 | 12:32 PM
Thanks Dabeechman,
I had all ready purchased the Dynatek. The only thing I had a problem with it was that the rev plug woudnt plug into the harness, so I used the cherry bomb. I sent the plug back to Dynatek, hopefully they can see why it wouldnt work.
Old Jul 16, 2006 | 04:04 PM
DaBeechMan's Avatar
that is weird. the one i installed was a pretty easy install.
let me know what dyna says
Old Jul 17, 2006 | 05:07 PM
Dyna called me, they said that this is the first they have seen. It was made wrong from the factory and that the plastic middle piece was pushed thru farther than normal and was glued in that position from factory. They dont have one to send me at the moment. But hopefully soon. I am using the cherry bomb for now.
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
meddy0388
Sep 9, 2015 06:41 AM
