sport tires on a 4x4?
Old Jul 9, 2006 | 02:01 AM
raidermike67's Avatar
Default sport tires on a 4x4?
What would happen if I put a set of smaller sport quad tires on my 4x4 Rincon 650? Pros/cons.....good/bad idea? I'm trying to lower my center of gravity a bit.
Old Jul 9, 2006 | 09:43 AM
v2rider's Avatar
Pros, better low and mid take off.
lighter machine
cheaper tire mabey
Cons, less traction in mud
probably not as puncture resistant with shorter lugs
less ground clearance
Old Jul 9, 2006 | 09:51 AM
Scooter86's Avatar
Knows Old ATV Questions!
Maybe some ITP XCT's? You can get sport quad tires in 6 ply, and with a shorter sidewall you might have better puncture resistance in some cases. Were you planning on putting some rear tires on the front too? What about the ITP ATR's? looks like they come in 25 or 26" though, but they would give you some lightness and handling.
Old Jul 9, 2006 | 10:38 AM
rolsmojave3's Avatar
Mikeyboyesg is running 22 inch holeshots in front and Gators in the rear on his Prairie. He likes the handling advantages. Look in the Kawasaki section or Pm him.
Old Jul 9, 2006 | 10:46 AM
>>>>>>>>>>>>&g t;
Ok, thanks.....I have a lady friend who rides my Rincon but is fairly new and doesn't care much for the body roll, neither do I.
Old Jul 9, 2006 | 04:00 PM
oldturtle's Avatar
If you go much smaller in diameter then you will be gearing the Rincon down and you cannot correct like a sport quad with sprocket changes. So avoid anything smaller than 24 in or else expect to be screaming the engine all the time. I also think ground clearance will be big issue. The Rincon is very stable for a utility as is so seems to me you are better off to look at stronger sidewall tires like Bighorns rather than going smaller.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
fd24
Jan 16, 2019 08:59 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jason Campbell
Sep 7, 2015 02:25 PM
black_thunder
Sep 7, 2015 01:24 AM
