cam chain ?
Old Jul 10, 2006 | 09:38 AM
kawiking's Avatar
Default cam chain ?
when im drag racing i take off in 2nd.it leaves the line hard,but when i shift into 3rd it feels like im losing some torque. im not sure if i have the jetting off on the new carb or if its caused by my timing chain being loose. i have about 2 clicks on my adjuster right now . i have a new chain and its going on this week. can your cams jump time because off a loose chain? and if they do how would it effect it. my bike should be running harder than what it is.
Old Jul 10, 2006 | 09:49 PM
kawiking's Avatar
Default cam chain ?
Old Jul 10, 2006 | 11:03 PM
mucky's Avatar
Default cam chain ?
no they cant jump time because of the chain guide thats above it. but if its loose it changes the valve timing a little and you loose power.
thats what mine did, plus I had weak valve springs to add to the problem
Old Jul 11, 2006 | 01:54 AM
kawiking's Avatar
Default cam chain ?
how would diffrent spark curves effect how it runs. i have a procom with 3 diffrent curves and i have it on the middle 1 and + 100 rpms.
Old Jul 12, 2006 | 12:19 AM
mucky's Avatar
Default cam chain ?
depending on which curve its on it could retard or advance the spark, to far advanced will cause heat and to much retarding can give backfires in the intake, I run the dana cdi and have it on #3 it retards it a little from stock, i've tried #1, #2 and #4 and it makes mine run like crap. #3 for me is the best
try running it in all the positions and see what runs the best
Old Jul 12, 2006 | 12:46 AM
kawiking's Avatar
Default cam chain ?
i have 9 settings on mine. 3 curves stock rpm,then +1000 and +2000. i run it on #5 ,2nd curve with +1000. i had it on #6 the other day.????? i went riding to day and put it on 5. ran alot better!!!! i think when im dragging i stay in 2nd to long. i start off in 2nd, i shifted into 3rd alot sooner and it felt strong!!! my bike revs up fast!! even trail riding ,i hardly ever use 1st gear.
my buddy/mechanic is going to do my timing chain this week ,so... hopefully im going to get it running right.thanks for the help again mucky!!
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
