King Quad Oil Change
Old Jul 12, 2006 | 10:15 AM
jverch1's Avatar
Default King Quad Oil Change
I was wondering if it would be ok to put Mobile 1 Syn. Oil in my 05' King Quad. I heard several mixed opinions. If it does cause problems, would it do the same in an 05' Auto Vinson. Please advise. Thanks.
Old Jul 12, 2006 | 03:18 PM
nate712's Avatar
not sure about mobil 1 but i know Royal Purple just came out with a motorcycle/ atv oil, RP oil is very good oil I use it in everything i own but it is kind of expensive about $10 a quart. I would try that. I will be putting it in my king quad as soon as it is broke in properly, about another 5 hrs.
Old Jul 13, 2006 | 03:32 AM
DavAsh's Avatar
Make sure that whatever oil you use is wet clutch compatible. I use Amsoil and have never had an issue with it.
Thanks
David
Old Jul 13, 2006 | 02:49 PM
RedGoblin's Avatar
Make sure you've got a good, solid filter wrench. When I did mine, I think I almost killed myself trying to get the freakin' filter off.
Old Jul 13, 2006 | 08:38 PM
builditbig's Avatar
I also use amsoil there is several good ones out there I use 0-40 and have use 10-40 just make sure you are not using oil with a friction modifier. use wet clutch oil
05 king quad
06 Vinson
Frisky2050
Apr 9, 2020 11:19 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
