03 z400 carb-stripped screws
Old Jul 26, 2006 | 08:31 PM
staggarlee's Avatar
Default 03 z400 carb-stripped screws
What's the best tool to use to remove the stripped screws from the float cover? I sure wish they were bolts.
Old Jul 26, 2006 | 09:23 PM
1of4Horsemen's Avatar
Pale Rider
With my goldfish shorts swimmin' around my toes.
Try an EZ-out or one of those Craftsman screw removing tools. Can't remember the exact name of it but they work good. Then I suggest you replace them with allen head screws, they don't strip out as easy.
Old Jul 26, 2006 | 11:13 PM
mucky's Avatar
if its just the head of the screw where the screw driver/allen wrench goes, take a small drill and drill the heads off the screws and then remove the float bowl and you should be able to remove the screws then
Old Jul 27, 2006 | 10:52 AM
ShadyRascal's Avatar
I had this prob with mine. I went and bought a screw removal tool for about ten bucks, fiddled with that thing, cussed and yelled, housrs went by, didn't get anywhere, ready to junk the whole bike, then I took the carb down the the Yamaha shop to my man Todd. He casually took a very small chisel out of his tool chest, layed that carb on the table, positioned that chisel so it would dig into the side of the screw head and push counterclockwise, and one or two taps that sucker was loose. No charge. That guy walks on water.
Old Jul 27, 2006 | 11:36 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
I used a dremel and cut a slot in them big enough for a flat blade screwdriver.
Old Jul 27, 2006 | 01:44 PM
hondabuster's Avatar
To keep the heads from rounding the next time, buy a ACR Philips screwdriver. It has ribs on the cross, to keep the screwdriver from camming out.
Old Jul 29, 2006 | 11:42 AM
witti's Avatar
Same way I did it.
Old Jul 29, 2006 | 07:33 PM
yamahawarriormods's Avatar
drill or i have used a hack say to cut a slit in it seams to work well
Old Aug 27, 2006 | 08:16 PM
staggarlee's Avatar
Thanks for the tips guys! The dremmel worked great. Found dirt in the bowl, cleaned everything, and it runs great now.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
