Help! need king quad 300 regulator wiring dia
Old Jul 28, 2006 | 11:06 AM
chuckinnc's Avatar
Default Help! need king quad 300 regulator wiring dia
I recently bought a 96 - 300 king quad for my grandson, as i was checking it out i noticed the ignition would cut out
sometimes when you first started up, i also found that turning on the lights made it run ok so i figured the voltage was to high. After checking it with a meter it runs 17.5 volts! I dont want to haul the quad back 78 miles where i got it from if i can fix the problem here, so can anyone email, fax me or tell me if theirs a website where i can find the wiring diagram for the (Voltage regulator) ?
Old Jul 30, 2006 | 09:51 AM
Scottishquads's Avatar
Your best bet is to fit a new regulator. It is located in front of the handlebars below the fender.
moneyman01
Jul 11, 2015 08:50 PM
Ragtop
Jun 27, 2015 03:04 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
Wolverine16
May 18, 2000 09:18 AM
