Zee front brakes
Old Aug 18, 2006 | 11:24 PM
cataway's Avatar
Default Zee front brakes
the front brakes on the z 400 suck, at least mine do .and i found out that others have the same problem . i was wondering if the master cylinder of the Honda 450r will fit and work on the Z 400? any experience out there with this idea?
Old Aug 18, 2006 | 11:43 PM
hondabuster's Avatar
What kind of symptoms does it have? It should effortlessly lock both fronts.
What has changed... or has it always been this way since new?
Old Aug 18, 2006 | 11:57 PM
cataway's Avatar
i agree it should lock em up but i and others can only get them to lock up in the sand. the 450r will put you on your nose if your not carfull.
Old Aug 19, 2006 | 12:20 AM
powerstroke01's Avatar
Mine lockup on blacktop. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Aug 19, 2006 | 12:31 AM
cataway's Avatar
mine is an 03
Old Aug 19, 2006 | 12:49 AM
If youve bled them, and they are free of air, and still wont lock up...then it sounds like the caliper sliders are froze.
If you take the caliper off the disk can the calipers move side to side on the mounting bracket? The calipers need to float, so they can center on the disk. Did you just change pads?
Old Aug 19, 2006 | 12:53 AM
cataway's Avatar
oh ya been there done that .
Old Aug 19, 2006 | 12:54 AM
MIDDLEAGEDCRAZY's Avatar
Don't have any problem with mine yet. It's an 05.
Old Aug 19, 2006 | 12:56 AM
1of4Horsemen's Avatar
Pale Rider
With my goldfish shorts swimmin' around my toes.
Mine work just fine but it's an 05.
Old Aug 19, 2006 | 01:57 PM
mucky's Avatar
never had a problem with mine. still running stock brakes
