Zee front brakes
Old Aug 22, 2006 | 07:47 PM
cataway's Avatar
Default Zee front brakes
a guy on a another forum said that it mite be the brake lines , that the lines maybe expanding due to the pressure and not allowing the caliber to come out as much as it should. he recommend new stainless bradded brake lines . makes sence to me .you?
Old Aug 24, 2006 | 10:21 AM
witti's Avatar
mine is an 03
So is mine, they work good for me.
Someone from central said they installed a 450r master on their Z. Had a lot more stoping force, locked up easier. I would try brake lines first.
If you pump them do they work better? I bent a ft brake rotor and the brakes would hardly work on the first application. When I pumped them they would work fine. The bent rotor would push the piston out to far.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
carolinabomb
Jul 26, 2015 08:40 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
