Hard shifting on Ozark while it is cold
Old Sep 18, 2006 | 05:23 PM
AdrianXXX's Avatar
Default Hard shifting on Ozark while it is cold
I just got a new Ozark (2 hours on it). When the engine is cold it is almost impossible to shift up from the 1st gear to the 2nd. After warming up (by 10 min. easy riding) there is no problem anymore with the shifting.
Is it normal by a new Ozark? Will it be better in a time?
Why the shifting is dependent from the engine´s temperature?
Old Sep 18, 2006 | 05:25 PM
kickass210's Avatar
maybe it just needs to be broken in?
Old Sep 18, 2006 | 08:48 PM
GrnXnham's Avatar
Both of our Ozarks do the same thing so I'm thinking it's normal for Ozarks. Since it's better for the engine to warm it up for a few minutes before giving it full throttle anyway, it may be for the best that the Ozark is "flawed" in this way. We always start up our Ozarks and let them idle for a few minutes before riding them so we rarely notice the shifting problem.
I'm guessing it does this because it takes a few minutes for the engine oil to warm up and bathe the clutch/transmission since there is no separate transmission or clutch fluid?
Old Sep 18, 2006 | 11:06 PM
kfxandahemi's Avatar
When my dad has his ozark it did that when it was cold between 1st and 2nd. It quit after it got warm and didnt seem to do it as the machine got older.
Old Sep 18, 2006 | 11:52 PM
michigan2500hd's Avatar
Both of my Ozarks have shifting problems from time to time. More so when cold. It has got better with age though.
Old Sep 19, 2006 | 08:40 AM
AdrianXXX's Avatar
I am an amateur, so maybe the questions will sound stupid:
1.) Are the Transmission and Clutch bathed in a special gear oil?
2.) This oil´s temperature does depend from the engine´s oil temerature?
3.) Is that the reason, why the shifting is so hard while the engine is cold?
Thank you, Adrian
Old Sep 19, 2006 | 04:38 PM
bombrider04's Avatar
Its normal to have it shift hard I found a trick once i warmed it up though you rev the engine up a little bit and then shift and it seems to shift easier but make sure you let off the throttle when shifting. I had my ozark since 02 and loved the thing but just got rid of it for a new honda 450r.
Brandon400
Sep 7, 2015 12:20 PM
Elkaholic
Sep 6, 2015 02:44 PM
Pahuntman
Sep 5, 2015 11:07 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
