Top speed of a 1986 lt250r ?
Old Sep 18, 2006 | 10:12 PM
Kj16's Avatar
Default Top speed of a 1986 lt250r ?
I would like to kno the top speed of a stock 1986 lt250r. And how much faster would it go with a full fmf system
Old Sep 18, 2006 | 11:03 PM
bansheeyfz's Avatar
Im thinking 67-70 with a pipw maybe 70-75
Old Sep 19, 2006 | 09:29 PM
Baja226sport's Avatar
People will tell you 50 some mph but I have seen 61 mph (GPS) on my warrior and my 85 lt250r is a ton faster! So I'd say upper 60s at the least!
Old Sep 19, 2006 | 10:53 PM
RappinErnie's Avatar
I have read that the stock 85/86 Lt250r goes 53. They were geared really low. But alot of people are saying they go in the upper 60's. I still think it's around 53 STOCK.
Old Sep 19, 2006 | 11:25 PM
I suppose I'll have to run it out with the gps on me. I am not sure about anyone else's but I know that mine is faster than 53 mph. NOt to many mods, no airbox, jetted, dg pipe. Don't know if it is stock gearing or not. I'll have an updated gps top speed after this weekend.
Old Sep 21, 2006 | 02:36 AM
lt250rrider's Avatar
Please let us know I just got a milled head (now) with a fmf pipe !!!!!!!!!!!!!!!!!!!! Would give me a idea what this bike would run !
Old Mar 29, 2012 | 09:52 AM
Schowzy's Avatar
my 86 lt250r is built, and im sure that if a full fmf pipe set will get it to 70-75, then mine should do more than 67. it has stock gearing, cpi in frame drag pipe, dune porting, k&n filter, milled head, 36mm flat slide carb, and all i hit is 67 (gps tested)
Old Jul 3, 2012 | 01:23 AM
86quadracr's Avatar
Baja226 if your still out there I would be extremely appreciative if you would tell me what your jetting was on your 86 LT, I have the exact same setup and can not get an answer for where I need to start I just don't want to run a brand new motor lean on the first start
Old Oct 29, 2015 | 07:58 PM
Drags288's Avatar
My 86 has a stock rear sprocket and a 11tooth front and does 53mph in top of 4th. It is GPS and laser proven on a drag strip. Never had enough distance to hit 5th
Pehter
Oct 3, 2024 11:00 PM
Levi Enstad
Sep 26, 2015 08:00 AM
ReconBayou
Sep 23, 2015 02:41 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
Halffast17
Sep 11, 2015 02:30 PM
