eiger 4x4 snorkel
Old Aug 8, 2016 | 02:52 PM
fusco7710@gmail.com's Avatar
Default Questions
Originally Posted by baf004
http://pg.photos.yahoo.com/ph/baf004/my_photos
Here's my photo album, sorry it took me so long to get pics up.
The intake snorkel was created from 2 pcs. of 1 1/2" flex radiator hose, a 1 1/2" no hub connector, and a 1 1/2" pvc L. I glued it all together with plumbers goop. It's the best stuff for waterproofing, hands down. I also sprayed the duplicolor truck bed coating on the pvc and the square tubing support. It is holding up great and matches the radiator hose quite nicely.
The little quick release pvc T that you see above the airbox has the carb vent and the fan vent run up to it. Then the outlet is run up to the snorkel support above the front rack. I sealed this up with standard rain or shine pvc glue, since the quick release won't really be necessary.
The exhaust snorkel is a stock hmf endcap with some standard exhaust tubing jammed inside. I drilled 4 holes and popped rivets inside to keep it from falling out. I also made a gasket with RTV silicone on the end cap to prevent any water coming in. I also RTV'd the outside and inside of the end cap where the exhaust tubing is jammed inside. It also helped the RTV the heads of the pop rivets to keep air from escaping/water from entering through them. As you can see, I don't have it mounted up right now. I just got a new end cap to put on whenever I don't need the snorkel.
I like the HMF sound with both the stock end cap or the snorkeled end cap. It's crazy loud with the extra pipe sticking up in the back, and without the snorkel it's got a mean low rumble to it.
Anyhow, if you have any questions after viewing the pics, please just let me know.
-Blake
How are you doing buddy. Is there anyway you can email the pics to me fusco7710@gmail.com because I can not seem to pull them up on here. I got a 2004 Suzuki eiger 400 and can't find a snorkel kit anywhere and would like to make one for mine. Thank you
Old Jul 30, 2022 | 08:44 PM
Mason Berry's Avatar
Default Help with snorkel
I dont know exactly how to snorkel my susuki Eiger quadrunner 400 4x4.
Customer Service #1
May 15, 2020 08:46 AM
Steeldon
Sep 9, 2015 09:38 AM
Ean
Aug 20, 2015 07:13 AM
Cantbuytime
Aug 17, 2015 06:33 PM
baysport
Jul 23, 2015 11:37 AM
