suz 230 help
Old Oct 6, 2006 | 10:17 PM
laser16b's Avatar
Default suz 230 help
im rebuilding my 87 230 and need to no the touqe specs for the top end...head bolts and such...also i cant seem to fine the timing mark on the cam gear...thanks for any help on this
Old Oct 7, 2006 | 07:56 PM
redneckfromnb's Avatar
i think the torque specs are about 22 pounds ant the timing marks are on the end of the cam.they are 2 slots and they have to be in line with the top of the head surface,at least thats what it is for my 250..hope this helps.
Old Oct 8, 2006 | 09:21 PM
dropride's Avatar
According to my clymer manual the cylinder head specs are 5-8 ft-lbs for the 6mm nuts and 15-18 ft-lbs for the 8mm nuts. The cylinder head cover bolts are 6.5-8 ft-lbs. The cylinder base nuts are 5-8 ft-lbs.
Old Oct 13, 2006 | 09:09 PM
laser16b's Avatar
thanks for the info guys
one more question....what should my ring end gap be...and could you explane the timing to me again as i no im going to mess that up...lol
