1986 LT 230. Need Help, electrical issues
Old Oct 9, 2006 | 07:03 PM
BREAK's Avatar
Default 1986 LT 230. Need Help, electrical issues
I'm new to this forum and I'm hoping I can find someone who can help me. I have a 1986 Suzuki LT 230 I bought for $400. It doesnt run, because the magneto cover was cracked due to a loose chain. I fixed this problem but I came up with another problem. My On/off switch wiring got cut off. I need to find out how to wire it back together so i can get it to start. Can anyone help me out?
Old Oct 9, 2006 | 09:12 PM
quadsport230's Avatar
the kill switch or the ignition switch
Old Oct 10, 2006 | 10:30 AM
BREAK's Avatar
I believe its the ignition switch
Old Oct 10, 2006 | 03:52 PM
hondabuster's Avatar
If no one offers up a wiring diagram, you can try the local library, they ususally have a few service repair manuals in the 629 section of non fiction. Ask the librian for help if you dont find it..because they can get one from another branch if there branch doesnt have one.
Ebay is another soarse for cheap service manuals.
Old Oct 11, 2006 | 11:59 PM
albung's Avatar
unplug wires that go to kill switch should fire right up
Old Oct 12, 2006 | 06:04 AM
pumpkin's Avatar
What is the kill switch, just a ground? If there is more than one wire ohm the wires to find the ground. Ground to ground should have continuity. Then just play with hooking up the other wire(s).
Old Oct 12, 2006 | 04:09 PM
yagerzzz's Avatar
The wiring diagram on the '86 sport is pretty simple because there is no key switch on the '86. Those weren't put on the sport until '87.
The kill switch on the handlebar below the hi/low switch is the only thing that kills the engine. It is simply a ground. Wiring the two wires together will not allow the engine to start. Or, if the actual switch has a malfunction, the engine may not be able to start. If you want to see if the engine will start, leave the wires unconnected.
Old Oct 14, 2006 | 10:40 PM
2FAST4URASS's Avatar
I have a 87 230 i bought it for 200 bucks it came out to be more than what i want to deal with has a brand new side cover on it and many other new parts i have pictures pm me if you need anything off it....
DeFox500
Jul 26, 2015 06:32 PM
JoAnnS
Jul 23, 2015 02:18 PM
Bratman2
Jul 23, 2015 12:36 PM
Unzzy66
Jul 11, 2015 10:01 PM
