Timming a 87 230 HELP!
Old Oct 14, 2006 | 07:15 PM
laser16b's Avatar
Default Timming a 87 230 HELP!
ive got a 87 230 quadrunner and i need to no how to time it...the crank timing is marked so thats a no brainer but i dont no where to set the cam, on the face of the cam there 2 dash marks on eather side in the middle and theres a E on the outer edge, other then those marks i see nothing...someone please help me with this, all i need to do is time the thing and ill be ripping up the trails...
thanks
laser16b
Old Oct 15, 2006 | 12:10 AM
quadsport230rider's Avatar
u line up the two lines on the cam with the surface of the head. i did that today on my quadsport 230
Old Oct 15, 2006 | 12:14 AM
laser16b's Avatar
i did that today but theres no compression at all...is it possable that its 180 degrees off...
Old Oct 15, 2006 | 12:23 AM
then the cam is upside down or it is differenton a quadrunner. i have a quadsport. do u kno the little **** that sticks out of the cam and sort of holds the sprocket on? is it over to the left or under to the right? mine is up to the left and i have compression
Old Oct 15, 2006 | 12:24 AM
so it sounds like ur cam is upside down if that would even matter
Old Oct 15, 2006 | 12:26 AM
laser16b's Avatar
ok tomorrow ill try rotating it 180 degrees and see what happens....hey man thanks a lot for the info
Old Oct 15, 2006 | 12:28 AM
sure thing im on the smae boat and im scared for mine now cuz it got dark out before i could start it so im crossing my fingers lol
Old Oct 15, 2006 | 12:30 AM
laser16b's Avatar
sounds like were working on the same quad...mine is also 87 quadsport
wiseco piston .20 over
ebc clutch
only the tires are diffrent
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
Chawness
May 1, 2001 10:34 PM
ChrisF
Aug 7, 2000 09:57 PM
yzf400f
Feb 23, 2000 04:08 PM
