wow z400 problem
Old Oct 17, 2006 | 12:05 AM
epic's Avatar
Default wow z400 problem
Hey, i was hearing some noises coming from timing chain when i was driving so i took the cover off took a look and it was worn out so i thought okay just a worn out timing chain no biggie. i then went to change my oil and when i started to let the oil out i saw little metal peices going out with the oil, first thing to come to my head was the timing chain flopping around and broke something so then i took off the clutch cover and saw more metal peices so then i took the clutch off and i took a look at the back of the clutch basket and there is 3 or 4 missing teeth. I was just wondering if is common for a z400
Old Oct 17, 2006 | 12:21 AM
ZButcheR's Avatar
LOL..."common" if it was i would not own 1...
NEVER.....
I think you got more going on then just timing chain or a clutch problem....
Old Oct 17, 2006 | 07:42 PM
mucky's Avatar
NEVER.....
ditto that. how old is the quad? make sure you didnt loose a chain guide and the timing chain wasnt rubbing against the case
Old Oct 17, 2006 | 07:47 PM
epic's Avatar
its a 2003 and its got all the guides, it should have to guides one on each side of the chain right?
Old Oct 18, 2006 | 12:31 AM
mucky's Avatar
it has 3 guides, 1 on each side and 1 between the cam gears, and by the way you found missing teeth on the clutch basket looks like broken basket or gear
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
