Eiger fuel issue?
Old Oct 30, 2006 | 02:20 AM
daviddsims's Avatar
Default Eiger fuel issue?
Went riding this weekend on alot of trails and my eiger died on me. It would idle fine but would go when I pushed the throttle more than a quarter of the way. Got back and pulled carb off and found an ant in the main jet. Put carb back on and ran great except it wont run with the petcock in the ON or RES position. It runs great on Prime. Could I have pinched a hose or something putting the carb back in? Anyone know how the vent line is supposed to hook up that goes to the carb?
Old Oct 30, 2006 | 08:50 AM
Rags1317's Avatar
Make sure you hooked all the hoses back up, if so! sounds like you reversed the vent & vacuum lines.
The vent from under the seat should go to a port on the left side of the carb close to the top that is angled up & back.
The other line is a vacuum line that goes to the fuel valve and opens it when the engine is running.
Old Oct 30, 2006 | 03:27 PM
daviddsims's Avatar
Well thanks Rags! I will pull it back apart and see. I saw a line that goes to the top of the carb and comes out under the seat that doesnt hook to anything. I havent seen the other vacuum line your talking about though. Also blew a fuse in my fan somehow or another.
Old Oct 30, 2006 | 04:21 PM
daviddsims's Avatar
Nevermind I found the vacuum line off on the back of the petcock. It was really difficult to see but I got it back on and it works great again.
Old Oct 31, 2006 | 12:35 AM
aksafari's Avatar
That was a great answer, Rags. Definitely a level above the usual blatherscyte you hear from most posters in here. Nice.
baysport
Jul 23, 2015 11:37 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 19, 2015 10:13 AM
Unzzy66
Jul 11, 2015 10:01 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
