Tire question
Old Nov 5, 2006 | 08:58 AM
akarotten's Avatar
Default Tire question
I need a quick answer if yall can on this ?.Ihave a chance to buy some tires size stated is front 23-8-10,rear size is 23-11-10.My atv is22-8-10,front,24-11-10 rear.Will these tires work on my rims?
Thanks,Paul
Old Nov 5, 2006 | 11:17 AM
mucky's Avatar
they'll fit, the fronts we be 1 inch taller and the rear 1 inch shorter than the ones you have now
23 = how tall , 8 = how wide , 10 = wheel diameter
Old Nov 5, 2006 | 01:42 PM
aksafari's Avatar
Absolutely not.
Your differential gears are set up for the difference in rotation between two different sized tires. You NEED the smaller tires in front and the larger in back. YOU CAN'T AVOID THIS. Or, you can break stuff. Up to you.
Old Nov 5, 2006 | 04:24 PM
akarotten's Avatar
So any reason i couldent put larger tires in rear?i was planing on doing that anyways.
Old Nov 5, 2006 | 07:17 PM
mucky's Avatar
what quad are we putting the tires on?
Old Nov 5, 2006 | 07:33 PM
aksafari's Avatar
The ratio between the front and rear tires needs to stay within 5% or so of the original factory tires. Calculate it, then you'll know if it's ok.
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
Ean
Aug 28, 2015 09:39 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
